toshiba 58l1350uc - Not Turning ON   Goto page 1, 2  Next
kkearsey
PostPosted: Fri Oct 07, 2016 9:52 am    Post subject: toshiba 58l1350uc - Not Turning ON Reply with quote
I have a 58" Toshiba 58l1350uc TV. I was watching tv one day and it turned off by itself. There is no sign of power, no lights, no audio.
I checked voltage at the AC in at it read 120V, and I read 5.0V to the mainboard from Power board. I also read 3.3V to power button. I replaced the mainboard yesterday with no change in the TV.
Any ideas where to check next?
Thanks,
PostPosted: Fri Oct 07, 2016 2:09 pm    Post subject: Reply with quote
See if PWRON toggles with each press of power button.
Check FET Q301.
kkearsey
PostPosted: Sat Oct 08, 2016 6:54 am    Post subject: Reply with quote
Thanks for the response. I'm not that tech savvy. But what do you mean toggle? And should I just be checking for a certain value on q301?
PostPosted: Sat Oct 08, 2016 10:25 am    Post subject: Reply with quote
Power Supply/LED Driver board Connector P802 - Pins# 10 and 14 = 5VCC - 5 volts VCC - There all the time the set is supplied with Mains (120V AC) power.
P802 Pin# 12 = PWON Power on/off - This pin should change (toggle) from one voltage state to another with each press of the Power Button (example: 0 volts to 5 volts). Of course, the set has to be supplied with Mains power.
Both the above reference GND2 (Chassis).
Measuring for continuity between pins - looking for dead shorts.
kkearsey
PostPosted: Mon Oct 10, 2016 11:04 am    Post subject: Reply with quote
PWON is showing 2.9v even when power button is pressed.
PostPosted: Mon Oct 10, 2016 12:07 pm    Post subject: Reply with quote
JTS1957 wrote:
This pin should change (toggle) from one voltage state to another with each press of the Power Button (example: 0 volts to 5 volts.
Does that pin do 2.9 volts irregardless of how many presses of the Power button occur? Is it the same for both Main boards?
Can you confirm Power and Main board part numbers?
kkearsey
PostPosted: Tue Oct 11, 2016 4:04 pm    Post subject: Reply with quote
It is 2.9 continuously no matter how many times I push power button. I don't have the original main board. I had to send that back to manufacturer. Power board was never changed
PostPosted: Tue Oct 11, 2016 4:16 pm    Post subject: Reply with quote
Take a 1000 ohm resistor. Momentarily hook one end to the PWON pin and the other to Ground. Once the magic smoke clears (jk) report results.
gamermitch
PostPosted: Sun Nov 27, 2016 11:33 pm    Post subject: Reply with quote
I am having the same problem with my TV but I can't even get the thing apart without breaking it... do I have to take the front edge pieces off or what?
PostPosted: Mon Nov 28, 2016 6:49 am    Post subject: Reply with quote
In my perusing of the web, I discovered two other persons with this set who were able to remove the back cover.
Goto page 1, 2  Next
Page 1 of 2
