_tech Guest
Posted: Fri Nov 07, 2008 12:06 pm Post subject: Toshiba 61H71 dead |
Toshiba 61H71 dead , chassis TAC0157 , Fuses F850 and F852 opened , cannot find the culprit. All I check is good (hot , caps , diodes , bridges, transistors). I've tought of vertical Ic , been change , fuses blow again.
Any ideas ?? |
_eric Guest
Posted: Fri Nov 07, 2008 12:07 pm Post subject: |
Did you check the jumpers by the Convergence IC's for bad solder? |
_tech Guest
Thanks
you were right on !! cracked solder on these 2 wire jumpers, soldering repaired the set.
I dunno why a cracked solder around these make 2 fuses blown right away thou.
The biggest job was to move this monster (61 inches). |
Disclaimer:
Privacy Policy
Advertise on RiddedTV.com
