Toshiba CE36T11 TAC 9915 is losing it's picture
Gravin
PostPosted: Mon Jul 01, 2013 2:49 pm    Post subject: Toshiba CE36T11 TAC 9915 is losing it's picture Reply with quote
I noticed several months ago, every once in a while the screen would lighten up and then the top would start to smoosh down a bit, creating a white line at the top of the image only to appear shortly. If it lasted longer than three seconds I would turn the box off then on again and the problem was solved. Two days ago, everything went black and white so I immediately turned it off and left it. It was fine until this morning.. I turned it on and the screen very quickly faded to black and now nothing will show. I unplugged it and let it sit for ten minutes. then screen came on for two minutes before blacking out again. Its now unplugged waiting for more professional advice. Please help!!
PostPosted: Tue Jul 02, 2013 10:33 am    Post subject: Reply with quote
Sounds like a bad vertical circuit. Probably a capacitor right next to the main Vertical IC.
