Toshiba CF30F40R No vertical   Goto page 1, 2, 3  Next
chumba
PostPosted: Mon Dec 06, 2010 9:30 am    Post subject: Toshiba CF30F40R No vertical Reply with quote
Have a Toshiba CF30F40R, chassis TAC 9632 with just a thin horizontal line. Resoldered the IC connections and other local parts but still problem exists.
If I bang hard on either side of the cabinet the full screen sometimes comes back, but then reverts back to the thin line a few minutes later. Before this problem started, I noticed the vertical was jumping a bit on the bottom of the screen. Please help. Thx Rolling Eyes
PostPosted: Mon Dec 06, 2010 10:09 am    Post subject: Reply with quote
if you can get it to come back by banging on it, its definitely a broken circuit trace somewhere. Get a bright light and a magnifying glass, and start soldering everything
sdtv
PostPosted: Sat Dec 11, 2010 8:37 pm    Post subject: Reply with quote
Sometimes the bad connection is the yoke connector where the wires are crimped.
Try wiggling the connector where it plugs into the main board.
chumba
PostPosted: Fri Dec 17, 2010 6:26 pm    Post subject: Reply with quote
I resoldered all the connections but still same problem exits, except that now the full screen does not appear after banging on the side.
Would the vertical IC be part # STR-Z4151? It is a 14 pin chip with a large heat sink and a separate clip onto the heat sink. Could not find any data sheets on it.
PostPosted: Fri Dec 17, 2010 7:12 pm    Post subject: Reply with quote
TA8427 check solder joints first.
Check electrolytic caps in that same area. Their location numbers should start with the same "hundreds" series. Look for one in the 100ufd to 220ufd range especially.
chumba
PostPosted: Sun Jan 16, 2011 8:16 pm    Post subject: Reply with quote
Thanks for the vertical IC part number...now that I'm in the correct section of the board, I resoldered everything in the 300 number section (the IC is Q301). I ohmed out all 7 pins of this IC to their next point and all tested good, so doesnt appear to be broken PCB traces. Also disconnected and reconnected the yoke and PCB connectors. Also tried adjusting the "Screen" control a bit.
The only electrolytic cap in this section is C320=100mfd. Swapped it out but problem persists after all the above.
PostPosted: Sun Jan 16, 2011 9:36 pm    Post subject: Reply with quote
Have you tried swapping out the IC?
chumba
PostPosted: Tue Jan 18, 2011 11:54 am    Post subject: Reply with quote
No, haven't swapped out the IC, would have to buy a new one. What else should I try 1st? How about the other non electrolytic caps and/or resistors and/or diodes in the same section of location numbers?
PostPosted: Tue Jan 18, 2011 5:03 pm    Post subject: Reply with quote
Most others seldom fail.
Other than posting the voltages on all IC pins, I can't think of anything else you should do.
chumba
PostPosted: Sun Mar 27, 2011 2:45 pm    Post subject: Reply with quote
After sniffing around some more, found that 500mA Fuse F301 was blown. However I replaced the fuse and it immediately blew.
Page 1 of 3
