Toshiba CF36G40 - lines & noise
1968RT
PostPosted: Tue May 24, 2016 9:37 pm    Post subject: Toshiba CF36G40 - lines & noise Reply with quote
Toshiba CF36G40 Chassis TAC 9609 Ser# 95566261
Just started today - intermittent horizontal lines on screen with accompanying crackling in audio. Watched the entire Tiger's game with no problem, then it came on for 5 - 10 minutes, then went away again. Does the fact that the problem affects both video and audio point to anything? I have cable TV and no other TV set is showing this problem.
PostPosted: Wed May 25, 2016 10:01 am    Post subject: Reply with quote
Bad solder joint in the Power Supply or Flyback areas is one possibility.
