CelicaSupra
Posted: Wed Nov 30, 2011 9:00 am Post subject: Toshiba regza 32AV615DB strange problem |
OK I'm looking at this set & as it came out of the garage in the cold it seemed to have no fault, within about 30sec of being switched on though the brightness appeared to be switching up/down in about 3 second intervals. After seeing this & switching off the input source (an old sky box) the sky menu could still be seen faintly in the background, this did not vanish when the set was powered off/on again & was kinda like screenburn but fading each time the set was switched off/on.
Eventually (maybe 10mins of use) the original fault it was out of use for showed up, still in the 3 second cycles like the brightness thing when i first looked, but now the picture was 3 seconds good picture & then 3 seconds of stuff jumping a couple of inches further down the screen & appearing to be "melted" vertically down the screen.
Not the best description i know, but its kinda tough to describe, will try and get a couple of pics showing the fault.
I saw a pic of similar "melted" effect on a thread regarding a toshiba plasma tv on here, wonder if theres a common "weak" component/solder joint they share like the old toshiba vertical deflection thing on CRT's?
Anyone got any ideas would appreciate the help!  |
CelicaSupra
Posted: Sun Dec 04, 2011 4:54 am Post subject: |
Nobody?
OK I'll try find a camera & get some pics shortly, but the more i think of it the more I reckon its a bad t-con board, sound plausible? |
CelicaSupra
Posted: Sun Dec 04, 2011 6:01 am Post subject: |
Right some pics of the problem & hopefully the top one will work as a video too if you click on it...
Soooo then, t-con a reasonable assumption? |
ianc153
Posted: Thu Aug 30, 2012 3:32 am Post subject: |
Hi, don't know if you are still posting on this forum...
i have had this television for 2yrs 10mnths and its displaying this same problem.
did you ever get this fixed? what was the problem?
can anybody help please? |
bikermack
Posted: Sun Jul 06, 2014 8:25 am Post subject: |
Yes, it was the T-Con card  |
