Toshiba Remote will not work
dukerdriver
PostPosted: Wed Apr 01, 2009 4:34 am    Post subject: Toshiba Remote will not work Reply with quote
Does anyone have the answer for this one?
The remote for my toshiba tv quit working a couple of days ago. Put fresh batteries in and still nothing. Purchased an RCA universal remote and fresh batteries and tried all the toshiba codes and still nothing. Used the code search function in the universal instruction manual and still nothing. Has any one had this problem?
Thanks,
Duke
PostPosted: Wed Apr 01, 2009 6:02 am    Post subject: Reply with quote
either the remote receiver is not working, or you got a universal remote that is not compatible with your TV.
I would guess the receiver is not working.
dukerdriver
PostPosted: Wed Apr 01, 2009 6:32 am    Post subject: remote receiver not working? where in the world is it? Reply with quote
I kind of figured that there must be someting in the tv that receives the signal from the hand held remote. I fished around the net and found a remote reciever for $7.95 and just wonder where it is located in the tv. The web site did not have a picture. Is it some kind of circuit board that simply snaps out and the new one snaps in place? Any experience with this would be appreciated. Thanks, Duke
PostPosted: Wed Apr 01, 2009 7:49 am    Post subject: Reply with quote
no, it will be integrated to the main board. Each receiver is unique to the model # of that particular TV.
You'll need to provide a model number if you want any specifics on components. But from the questions you have asked, I assume replacing these components is not really an option for you. Never the less, we can do our best to help.
dukerdriver
PostPosted: Wed Apr 01, 2009 3:11 pm    Post subject: Integrated? Reply with quote
Thanks for the information. I found a source for the remote reciever that was specific for the model number of the Toshiba tv. It did not show a picture, but the description is a circuit board. I ordered it and since it was under $10 I figured that the worse that could happen is that I have to eat the part. Is there any soldering involved?
I really want to thank you for taking the time to respond to my questions.
Have a great day.
Duke
braveswin
PostPosted: Wed May 12, 2010 11:34 am    Post subject: Toshiba needs a new remote receiver Reply with quote
Dukerdriver, I've got a similar situation. I have the 34HF84 and also bought the Remote Receiver component for $12.95 and now need to learn how to install it. I wasn't willing to pay the repairman $200+ for this. Shocked
Can anybody shed light on the details of this repair?
Thanks in advance.
Randy
PostPosted: Wed May 12, 2010 1:58 pm    Post subject: Reply with quote
Disassemble enough to get old unit out. Since is CRT set, most likely you'll have to slide out the main board.
Compare to new one to make sure they are the same. This will also inform you as to what you'll have to transfer from the old to the new, if anything, what you'll have to unsolder, etc.
Many videos on You Tube on soldering/desoldering, practicing on a junk board, if needed, is a good idea. Wink
