Toshiba TheaterView HD 43H70 Blue Ghosting - Convergence?
KC Cat
PostPosted: Mon Jan 11, 2010 9:20 pm    Post subject: Toshiba TheaterView HD 43H70 Blue Ghosting - Convergence? Reply with quote
Our TV has developed a color convergence problem recently. I tried to go to the on screen menu to adjust the convergence, but could not make the problem go away.
When adjusting the convergence, we have 9 spots on the tv screen, and the blue color cross is well above the others in the bottom left/middle/right spots.
I'm just now noticing that this double image, or ghosting effect is also occuring in the upper left spot too.
What is causing this, and what kind of cost range does the repair fall in?
Thanks!
PostPosted: Tue Jan 12, 2010 8:48 am    Post subject: Reply with quote
probably failed convergence ICs
PostPosted: Thu Jan 14, 2010 8:31 am    Post subject: Reply with quote
I just realized I didn't answer the second part of your question.
Done yourself: $40 + 3 hours
Done by a repair shop: $300
