Toshiba TN61X81 No Picture
SailorJerry
PostPosted: Wed Jan 27, 2010 2:37 pm    Post subject: Toshiba TN61X81 No Picture Reply with quote
The picture of my tv just happens to go out sometimes while watching when the picture goes out the CRTs are still glowing and if I press on one of the cooling elements the picture comes back on. Usually for quite a while before turning off again does anyone know what this could be?
Thanks!
PostPosted: Wed Jan 27, 2010 3:04 pm    Post subject: Reply with quote
cooling elements? If you're talking about a heat sink, it sounds like you have a cold solder joint problem.
You'll need to find the broken joint/trace and jumper across it.
SailorJerry
PostPosted: Wed Jan 27, 2010 4:47 pm    Post subject: Reply with quote
Yes its a heat sink and if I jimmy with it the picture comes back on. Cold solder meaning a solder connection maybe cracked or loose?
PostPosted: Wed Jan 27, 2010 8:08 pm    Post subject: Reply with quote
you got it.
SailorJerry
PostPosted: Thu Jan 28, 2010 11:07 am    Post subject: Reply with quote
Thank you kuhurdler for your input! Does anyone know if there is a notorious spot that these tvs have that goes bad? I am certainly not a tv repair man so if anyone would have any ideas on what to look for it would be greatly appreciated!
Thanks!
PostPosted: Thu Jan 28, 2010 12:14 pm    Post subject: Reply with quote
I usually troubleshoot bad solder joints by poking at the board with a wooden chopstick. If you can find an area that makes it turn off/on, you can probe a little more closely.
Disclaimer, be careful not to touch anything since you're messing with it while it is running.
