Toshiba TP50F50 Convergence
peterb
PostPosted: Wed Oct 08, 2008 9:38 am    Post subject: Toshiba TP50F50 Convergence Reply with quote
The convergence IC's were bad. I replaced the STK's.
The blue horiz is off. I don't have the original remote.
I am not sure of the code to get to the service menu.
My question is: What is the code to get to the service manual and do I need the original remote?
TIA,
Peter
peterb
PostPosted: Wed Oct 08, 2008 10:39 am    Post subject: Reply with quote
Follow up:
I did get into the first step of the service manaul.
I got the "S" in the upper right corner. When I push Menu I get "RCUT" on the screen. I need info from the service manual for this set. I am not too familiar with this model.
Any help would be appreciated.
Peter
PostPosted: Wed Oct 08, 2008 10:44 am    Post subject: Reply with quote
If the only problem you had was a defective STK and there are no burn't resistors you should be able to adjust the convergence completely from within the customer menu. (If the blue STK was indeed bad and you could not adjust the blue convergence, you most likely still have a bad resistor that is a very low value very close to the STK's you replaced. This bad resistor will still prevent you from adjusting the blue convergence but will not damage the new IC's)
If you intend to run a complete convergence from within the service menu you most likely will have to have the original remote.
