Toshiba TV Service Menu Codes - CRT / LCD
Toshiba
PostPosted: Sat Jul 21, 2007 1:51 am    Post subject: Toshiba TV Service Menu Codes - CRT / LCD Reply with quote
# Turn the TV on.
# Press the {MUTE} button three times on the remote.
# Press the {MUTE} button again on the remote and hold.
# Then press the {MENU} button on the TV's front panel.
# Release both buttons
# There should be a letter "S" on the upper right of the screen.
# Press the {MENU} button on the TV's front panel again.
# You are now in Service Menu.
# Use the {CH+} or {CH-} buttons to select the item.
# Use the {VOL+} and {VOL -} buttons to adjust the value.
# Turn the set off to exit the Service Menu.
Toshiba
PostPosted: Sat Jul 21, 2007 1:53 am    Post subject: Service Menu Access Reply with quote
* Turn the TV on.
* Press and hold the {VOL-} button on the TV.
* Press and hold the {9} button on the remote.
* The Service Menu will be displayed.
* Use the {CH+} or {CH-} buttons to select the item.
* Use the {VOL+} and {VOL -} buttons to adjust the value.
* Turn the set off to exit the Service Menu.
Toshiba
PostPosted: Sat Jul 21, 2007 2:01 am    Post subject: Service Menu Codes Reply with quote
LCDs :
* Press the {MENU} button on the remote.
* Highlight the "Picture" icon.
* Press the {9} {3} {0} {1} buttons
on the remote control.
with the following Modes:
"Options" - "Adjustments" - "Selections"
* Use the {OK} button to access and
navigate through these Modes.
* To change values use {VOL +} {VOL-) {P+} {P-}
* To exit, press the {MENU} button.
***Yet another Different Method*********************************
enter the main menu by pressing “M” button and then press the digits 4,
7, 2 and 5 respectively.
