using ESR meter
pete g
PostPosted: Thu Jan 14, 2010 3:12 pm    Post subject: using ESR meter Reply with quote
hi, i recently read that checking a cap that is in parallel with a low resistance could result in giving a false good reading. is this true? if so does this apply to all esr meters? congrats on a truly informative web site. sincerely, pg.
PostPosted: Thu Jan 14, 2010 3:53 pm    Post subject: Reply with quote
Yes, if there is a low value resistor in parallel to the capacitor, it will affect the measurement.
I find this to be somewhat rare in most circuits with capacitors. Particularly those with with electrolytic capacitors. It does happen occasionally though.
Like every tool, you still have to use your brain when your outcome just doesn't make sense.
pete g
PostPosted: Thu Jan 14, 2010 5:07 pm    Post subject: esr measurment Reply with quote
hi and thanks for your prompt reply. how low a value resistor? pg
PostPosted: Thu Jan 14, 2010 5:26 pm    Post subject: Reply with quote
Measure, with your ESR meter, various resistors you have in your parts bin, with and or without various value capacitors in parallel. This should give you a very good approximation. Wink
PostPosted: Fri Jan 15, 2010 9:52 am    Post subject: Reply with quote
anything less than 200 ohms would affect your measurements. the lower, the more it would effect.
