Posted: Thu Jan 06, 2011 8:56 pm Post subject: viewsonic LCD monitor VP930b no display, bad capacitors |
I got this LCD as a "you can have it if you want to try to fix it" pickup. I tend to be the recipient of a lot of this type of "charity".
It wouldn't turn on, the green light on the front just blinked in a weird pattern. Classic symptom of a bad power supply.
Opened it up and found qty 2 x 1000uF 16V electrolytic capacitors that were bulging in the corner of the power supply. Switched them out and and it is working good as new.
Nice Display, this is one of those that has multiple vga inputs as well as a DVI input. I'd guess it was top of the line when it was new back in 2006.
czappala
Posted: Mon Aug 01, 2011 8:42 am Post subject: Bad caps too. |
Just wanted to say thanks. This tip is still a classic. My 2006 ViewSonic VP930b LCD monitor went into the green LED blink mode yesterday. Sure enough, the same two caps have bulging rounded tops. In the process of warming up the soldering iron.  |
Posted: Mon Aug 01, 2011 11:00 am Post subject: |
Glad to hear. I'm still using mine right this moment. Great monitor. |
czappala
Posted: Mon Aug 01, 2011 4:55 pm Post subject: |
It took longer to find parts locally. But once in hand, the repair worked. I'm back to dual monitors again. |
