Visco VSC-32V3 Will not Turn On
Snowman58
PostPosted: Sat Mar 24, 2012 12:43 pm    Post subject: Visco VSC-32V3 Will not Turn On Reply with quote
I have a Visco VSC-32V3 that will not turn on. On power application, an orange light comes on & that is the end of any response.
I have read that the likely cause is a blown cap on the power supply (JSK3240-006, 72100030), however an inspection does not show damaged caps.
Does anyone have a circuit diagram with test voltages?
Or other suggestions for troubleshooting the problem?
Thanks
PostPosted: Sat Mar 24, 2012 2:52 pm    Post subject: Reply with quote
Visco Question
Snowman58
PostPosted: Sat Mar 24, 2012 3:08 pm    Post subject: Reply with quote
JTS1957 wrote:
Visco Question
Yes - a private label sold by Walmart (?).
Internally the same as Phillips from what I have read.
PostPosted: Sat Mar 24, 2012 3:53 pm    Post subject: Reply with quote
Shop Jimmy, Discount Merchant, ebay all show up on google search for PS.
Even when you deal with a more well known brand, you'll encounter some difficulty obtaining power supply documentation.
meng798651
PostPosted: Sat Apr 14, 2012 11:23 am    Post subject: Re: Visco VSC-32V3 Will not Turn On Reply with quote
Thanks
I have a schematic for the main board. I'm working on the exact issue. I think one of the IC's are bad. If your interested in the schematic let me know.
Snowman58
PostPosted: Sat Apr 14, 2012 1:28 pm    Post subject: Re: Visco VSC-32V3 Will not Turn On Reply with quote
[quote="meng798651]
I have a schematic for the main board. I'm working on the exact issue. I think one of the IC's are bad. If your interested in the schematic let me know.[/quote]
I would love to have a copy.
Thanks!!
meng798651
PostPosted: Mon Apr 16, 2012 1:11 am    Post subject: Re: Visco VSC-32V3 Will not Turn On Reply with quote
Snowman58 wrote:
[quote="meng798651]
Thanks!![/quote]
http://elektrotanya.com/konka_kdl32at23u,37at23u,42at23u.pdf/download.html
This is for the main board only. There's problem with these tv's when there's a storm. Enjoy
meng798651
PostPosted: Mon Apr 16, 2012 1:25 am    Post subject: Re: Visco VSC-32V3 Will not Turn On Reply with quote
Wait until you see "This file is downloadable free of charge from the site... processing"
Then click on the word "Get Manual"
Snowman58
PostPosted: Wed Apr 18, 2012 3:32 pm    Post subject: Re: Visco VSC-32V3 Will not Turn On Reply with quote
Got it!
Thanks
meng798651
PostPosted: Wed Apr 18, 2012 4:47 pm    Post subject: Re: Visco VSC-32V3 Will not Turn On Reply with quote
Your welcome
let me know what you find. It has to be a surface mount part thats bad. I don't have time to work on the one I have
