Vivitek RP51HD41-A philips knock-off i think
Donch
PostPosted: Tue Jun 22, 2010 8:29 pm    Post subject: Vivitek RP51HD41-A philips knock-off i think Reply with quote
Went and replaced the control module assembly (A/V inputs on back of tv) turned the tv on and the cooling fan acts as if the polarity is backwards or short in the system. the fan doesnt spin just ticks with the alternating current for the wall outlet it seems. i've retraced all lines/connections and all appear correct.
if let on for a few minutes the speakers will tick after the set warms up and repeat in a cycle fan..speakers...
any and all ideas/help would be greatly appreciated
Donch
PostPosted: Wed Jun 23, 2010 10:29 am    Post subject: update: put the a/v control module back in tv fires up fine Reply with quote
i still get lamp error i replaced the lamp tv tries to turn on but resets itself.
i unplug it try it again sometime tv will come on other times it takes 4-5 cycles of turning on reseting unplug... lil help
PostPosted: Wed Jun 23, 2010 11:59 am    Post subject: Reply with quote
those fans should be DC, so there's no reason they should be ticking 60 times per second.
I suspect a power supply problem.
What are the voltages at the fan input?
