Vizio Cooling Fan Recommendations??
jefe2241
PostPosted: Fri Dec 24, 2010 2:29 pm    Post subject: Vizio Cooling Fan Recommendations?? Reply with quote
I have a p50hdtv10a and a 20a and neither have cooling fans. I was wondering what you would recommend for cooling fans. They are 12v output. Let me know what you think.
Thanks
Jefe
PostPosted: Fri Dec 24, 2010 4:57 pm    Post subject: Reply with quote
This should do the trick ...
jefe2241
PostPosted: Fri Dec 24, 2010 5:00 pm    Post subject: Reply with quote
That should work! That might pull a little more than 12v...lol
PostPosted: Fri Dec 24, 2010 5:18 pm    Post subject: Reply with quote
Will run as long as it has a supply of aviation fuel.
Be sure set is fastened securely.
You'll probably need some noise-canceling headphones.
