Vizio E3D420VX - No Power
TylerP
PostPosted: Sun Apr 05, 2015 4:09 pm    Post subject: Vizio E3D420VX - No Power Reply with quote
First off, let me say thanks for the time and sorry if this question has been asked already, but the solutions I've been seeing haven't worked. I have a Vizio E3D420VX and it's around two years old. One day I pressed power and nothing worked. So far I've tried:
- different power sources/using no surge protector
- held power key down for a while/tried unplugging tv for a while
- replaced power cord
- searched for bad capacitors on the power board
- completely replaced the power board
After all this it still has no power, not even the LED light on the front. Any more input or suggestions would be greatly appreciated!
- Tyler P.
PostPosted: Sun Apr 05, 2015 4:30 pm    Post subject: Reply with quote
As you can see, Vizio may use a few different supplies (and Main boards) in this set.
http://www.shopjimmy.com/vizio/e3d420vx?cat=229&q=E3D420VX&tv_brands_select=Vizio&tv_models=Vizio+E3D420VX
http://www.shopjimmy.com/vizio/e3d420vx?cat=56&q=E3D420VX&tv_models=Vizio+E3D420VX
Which PS and Main board does YOUR particular version use?
TylerP
PostPosted: Tue Apr 07, 2015 3:49 pm    Post subject: Reply with quote
Oh I forgot to add that, the main board is a 3642-1512-0150
http://www.shopjimmy.com/vizio-3642-1512-0150-main-board-for-e3d420vx.htm
and the power board is 0500-0412-1380
http://www.shopjimmy.com/vizio-0500-0412-1380-power-supply-backlight-inverter.htm
I assumed it was like a computer in the aspect that I would at least see the computer respond in some way before it even got to the main board, if that makes any sense.
PostPosted: Tue Apr 07, 2015 4:25 pm    Post subject: Reply with quote
CN201 On Power Supply - Pin 1 = black dot
Is pin 12 (or 13)(or 14) 5.2 Volts all the time the set is plugged in?
Pin 3 (or 4) ON/OFF - Changes as power button is pressed? & changes back when power button is pressed a second time? (example: 0V then 3.3V)
IF On/Off behaves as indicated, does 12 Volts Pin 5 (or 6)(or 7) change along with it?
silkie
PostPosted: Sat Nov 28, 2015 7:32 am    Post subject: E3D420VX Reply with quote
Tylerp, We are having the same problem as well. Were you able to find the problem.
