VIZIO E420i-AO - No backlight
42395_skyline
PostPosted: Sat Jul 30, 2016 6:48 pm    Post subject: VIZIO E420i-AO - No backlight Reply with quote
I have a VIZIO E420i-AO that has no backlight. I can verify the display works via the flashlight test.
I have replaced the power and main board via eBay replacements and have the same issue. I tested the voltages on the new board going to the LED's by testing LED1, Vout1, LED2, Vout2. When the LED connector is unplugged and the TV is on I get abut .860V on LED1 and .890V on LED2 and 92-97V on Vout1 and 137-146V on Vout2. When the connector is plugged in and the TV is on I get 31-34V on LED1 and 55-62V on LED2 and 92-98V on Vout1 and 137-146V on Vout2.
Not sure if these reading are normal or not, but assuming they are how do I test the LED strips from the connector to see if the LED strips need to be replaced? I have a soldering iron and experienced in electronic repairs, just not TV's.
PostPosted: Sat Jul 30, 2016 10:30 pm    Post subject: Reply with quote
Scroll down to the two YouTube videos.
HERE
