Vizio E470i-AO schematic
tcole90
PostPosted: Sat Oct 14, 2017 10:25 am    Post subject: Vizio E470i-AO schematic Reply with quote
Looking for a schematic or parts list for a Vizio model E470i-AO power supply, power supply board number is 0500-0614-0270. Any help is greatly appreciated.
PostPosted: Sat Oct 14, 2017 1:52 pm    Post subject: Reply with quote
I don't think that there is a detailed schematic/parts list for many Vizio power supplies.
Models that use this power supply are also HIGHLY susceptible to LED failure. What may seem like a power supply failure may be caused by the failure of one or more LEDs inside the panel (screen).
SJ did have a Repair Kit:
http://www.shopjimmy.com/vizio-0500-0614-0270-pslf141401m-power-supply-led-board-repair-kit-for-e470i-a0.htm
Other than the 'looks' of one fuse, I believe this is the same:
https://www.shopjimmy.com/vizio-0500-0614-0300-pslf131401m-power-supply-led-board-repair-kit.htm
tcole90
PostPosted: Sat Oct 14, 2017 3:34 pm    Post subject: LED's OK Reply with quote
This is a power supply issue, the set had a blown main fuse, I replaced it and the shorted FET in the hot section, checked voltage across large capacitor and it was 162, and the TV had 5.4 volt standby, when I put the board in the TV and hit power it took out the fuse again along with the FET I had replaced. As far as the LED's I hooked 100 VDC to each line and they lit up fine with minimal current draw. Also thanks for the links.
