ghiros
Posted: Fri Jan 05, 2018 11:01 pm Post subject: Vizio E70-C3 - backlighting and ghosting |
Hello,
I just got this TV and I'm hoping that somebody can confirm what my issues are.
Here are two pictures of what I believe is some bad LEDs in the backlighting:
https://ibb.co/mWnBwb
https://ibb.co/jbhY9w
And here is a video of the screen. On the right edge the content seems to linger and then fades slowly. Not sure if this is considered ghosting. What is the likely cause of this?
https://youtu.be/SQce7u1vd0g
The TV is a Vizio E70-C3 (70" LCD). Thanks for your help! |
ghiros
Posted: Sat Jan 06, 2018 4:13 pm Post subject: |
Thanks. I saw that product and I'm pretty sure this would fix one issue. I'm more curious about the smudges on the right edge. |
Posted: Tue Jan 09, 2018 10:47 am Post subject: |
I've seen bad T-cons that behave that way. |
ghiros
Posted: Tue Jan 09, 2018 11:23 am Post subject: |
Thank you! Looks like they are really cheap to get. I just don't want to put money into this thing and then not being able to fix all issues. |
ghiros
Posted: Sun Jan 21, 2018 12:18 am Post subject: |
So I exchanged all the LED strips (didn't have any means to test them) and the shadow/dark spot is unchanged. Any ideas?
(haven't been able to replace the T-Con board - should be here Monday)
Thanks! |
Posted: Wed Jan 24, 2018 12:58 pm Post subject: |
please do let us know how it turns out with the new T-Con |
ghiros
Posted: Wed Jan 24, 2018 10:33 pm Post subject: |
No dice. Absolutely no changes with the new T-Con. I'm about to give up. |
ghiros
Posted: Thu Jan 25, 2018 7:56 pm Post subject: |
What is the chance of the mainboard being the problem? The only other thing I can think of are the boards hardwired to the panel. In that case it'd be a loss I guess. |
