Vizio GV47L FHDTV screen black
Critofer
PostPosted: Sun Aug 14, 2011 5:23 pm    Post subject: Vizio GV47L FHDTV screen black Reply with quote
Hey guys,
So I got a Vizio GV47L Tv. My friend gave it to me because he said it was broken but it looked in perfect condition so I am trying to fix it.
When I plug in the TV the VIZIO symbol turns orange. When you press the power button on the tv it will turn the VIZIO symbol white then the symbol dims. the power button, channel, volume, menu, source etc.. turn orange. Nothing then responds. the tv stays black the backlight doesnt turn on. you cant shut off the tv unless you unplug it. the volume channels etc buttons dont do anything.
I took the back off the tv and took a piece of wire and put it on each end of the F3 fuse then turned the TV back on. the backlight on the tv comes on now. the power, channel, volumes, bttons turn from orange then turn dark. Like I said the TV turns on now but nothing still works, the tv still wont shut off unless you unplug it. channel and volume does nothing.
I am 16 years old so I dont really now what I am doing. I would really like to fix this thing because It would be the best TV in my house.
Anyone know how to fix this issue?
Thanks!
Chris
PostPosted: Sun Aug 14, 2011 8:15 pm    Post subject: Reply with quote
Generally most newer sets are going to "look" to be in "perfect condition." This is because the lifespan of these sets is quite low (compared to CRT sets).
You DO know there's a reason Vizio chose NOT to save a penny or two by hard-wiring in a wire in place of that fuse?
If the set is continually blowing the correct value fuse - there is a reason.
Hope you have smoke detectors in your residence. Especially if it's old and uses a screw-in fuse fusebox.
Critofer
PostPosted: Mon Aug 15, 2011 4:41 am    Post subject: Reply with quote
Okay, Anyone else have any idea on how to fix this tv?
2004FLHRSI
PostPosted: Mon Aug 15, 2011 8:18 am    Post subject: Reply with quote
Did your symptom change when you bypassed the fuse? I don't read that in your original post, if it did. Was the fuse blown? Easiest test is with an ohm meter on low setting. (power removed!) Or by using a neon circuit tester across the fuse (with power on)
If you never get the backlights to turn-up, I'd say the problem is in your PS - but need to make sure the PS is being commanded to turn-on. There should be a trigger from the other board.
If you've bypassed a fuse, you've got a smoker in the making. Remember, all TV's are old enough to smoke. Beware.
Good luck.
