vizio m701d-a3r - left side video dark with lines
ruffing1
PostPosted: Tue May 26, 2015 8:51 pm    Post subject: vizio m701d-a3r - left side video dark with lines Reply with quote
Problem: Blue line on the left hand side horizontal. Left hand side picture is very dark, almost black. Right hand side normal. Color on left hand side is a different color than the right, more bluish in color. Took apart, looked at the cables, no change. It is an LED Visio model M701d-a3r 70".
Any ideas on how to fix this problem?
Please help
http://s1167.photobucket.com/user/Shawn_Ruffing/media/IMG_1135_zpsiceronao.jpg.html
http://s1167.photobucket.com/user/Shawn_Ruffing/media/IMG_1133_zps4mcyvhiz.jpg.html?sort=3&o=1
ruffing1
PostPosted: Thu May 28, 2015 7:30 am    Post subject: From vizio Reply with quote
After reviewing the pictures you sent regarding the dark area on the TV, it has been deemed to be a panel related issue and thus not a repairable issue. Since your TV is no longer under
Warranty unfortunately we cannot set up replacement for you. If you have extended protection thru the credit card you used please file a claim thru them and if you need anything
Further from us please let me know.
Thanks, Mark
MARK SIEWERT
VIZIO // TECH SUPPORT LEVEL 3
877-878-4946
800 STEVENS PORT DR, STE DD750, DAKOTA DUNES SD 57049
PostPosted: Thu May 28, 2015 11:22 am    Post subject: Reply with quote
Well there you go then. Shocked
If true, sounds like almost admitting the s**tty quality of the build. You know dam well that the designers recommendations for better reliability tab attachments were axed in favor of the much cheaper, less reliable method actually implemented.
