Vizio p50hdtv10a Blue Vertical line
jefe2241
PostPosted: Sun Dec 26, 2010 9:36 pm    Post subject: Vizio p50hdtv10a Blue Vertical line Reply with quote
I have a p50hdtv10a that none of the inputs work other than rca or components. On them I can get sound and the pictures seems to try to come across they are all vertical lines that scroll left to right with the movie that I put it but cant make out a picture. I can push the menu button and i can see that it comes up but its in a vertical line matter. All the other inputs don't work at all no video or sound. It seems that its not receiving any signal at all. When they are on all the other inputs I get a blue vertical line right down the center with another whiter colored line inside the blue line. When I try to push the input button to change it it goes to a vertical green line about 4 inches across. I checked all the voltages on the Power board seem to be OK. Changed out the ysus board and the logic board still the same problem.
So has anyone else had this problem? I am now thinking about the tuner board/input board to replace. What do you think?
http://i128.photobucket.com/albums/p...P1020782-1.jpg
http://i128.photobucket.com/albums/p...P1020784-1.jpg
Thanks,
Jefe Sad
PostPosted: Mon Dec 27, 2010 3:19 am    Post subject: Reply with quote
links no worky. Rolling Eyes
ranjefter1
PostPosted: Mon Nov 18, 2013 6:36 pm    Post subject: Reply with quote
Yes I have the same problem. But I'm getting to much voltage from power board out to Y and z boards. Says 5V near connectors and when I checked them they have 10V coming out of power board. Do I replace power board?
