Vizio VL420M - Main Board
Johnlm
PostPosted: Sun May 31, 2015 12:21 am    Post subject: Vizio VL420M - Main Board Reply with quote
I have been searching for quite a while for the main board to my 42" Vizio. The information I have is Vizio 42" 1080P LCD FHDTV 120HZ VL420M MAIN BOARD 3642-0682-0150. Everywhere I look, the suppliers show the board on their site, but they all say they are out of stock. Does anyone know if it's possible to find this board somewhere?
My tv can be operated via the buttons, but not via the remote. Also, the only input that operates is the Compostite 1 input. All other inputs went away one at a time unit I am left with just the one. I have been told the main board will fix this, but I CAN'T FIND ONE!! Any help would be greatly appreciated.
PostPosted: Sun May 31, 2015 9:52 am    Post subject: Reply with quote
IF all else fails ...
http://www.moduslinkptstvboards.com/3642-0682-0150/
Repair & Return option.
Johnlm
PostPosted: Sat Jun 13, 2015 9:38 am    Post subject: Thank you. Reply with quote
All else has failed, so I will be using the Moduslink Repair and Return service. Thank you for pointing me to it.
PostPosted: Tue Jul 14, 2015 7:19 am    Post subject: Reply with quote
If you're able to handle surface mount soldering, this appears to be the solution for most of these boards: http://amzn.to/1UY0RxD
