Vizio VO37LHDTVA10
zarfu
PostPosted: Tue Sep 24, 2013 3:58 pm    Post subject: Vizio VO37LHDTVA10 Reply with quote
Looking for some help with my VO37LHDTVA10.
I experienced the 'yellow light' issue with this TV where the TV would not power on. After reading around on the web, I checked the power board for bulged capacitors and burn out, as well as the mainboard. Everything seemed in order. I decided to ordered a replacement power board and mainboard to see if there was an issue that I could not observe.
I first replaced the power board, which had no effect. I put the original power board back in and then replaced the mainboard. The TV suddenly powered on. Progress...
Now I'm stumped however by three problems:
1) The screen is off-center, hazy, and obviously not as it should be (photo: http://sdrv.ms/14EDHTL)
2) None of the buttons on the side of the TV work except the power button.
3) The remote does nothing.
tvrepairtech
PostPosted: Fri Oct 04, 2013 8:46 am    Post subject: Re: Vizio VO37LHDTVA10 Reply with quote
Hi! Before you order the main board , you need to get the part number, and not by description, but by the part number from a paper sticker on the board itself. There is a small paper sticker with a bar code, and a long number, that's what you need when you order the main board, otherwise you may order a main board which may look the same but for different tv.
