max
Posted: Sun Oct 05, 2014 3:53 pm Post subject: VIZIO VP322 HDTV10 |
I have a 42" VIZIO VP322 HDTV10A, I heard a loud bursting noise then no picture or sound just a black monitor. The vizio light turns white when the power is turned on then noting. I removed the back and I see 2-3 capacitors that or burst or bulging on the power supply board, but when I turn the power on d-104 on the logic board turns green then turns off, and I hear a ringing noise that last for about 6-10 seconds max then stops on the board to the left of the power supply board, I'm not sure what it's called but it's not the one connected to the inputs (HDMI, RCA'S etc). Should replacing the capacitors fix this or do i have a bigger issue? |
