_Paul Guest
Posted: Tue Sep 22, 2009 10:50 am Post subject: Vizio VP422HDTV10A plasma no pic |
Have this Vizio VP422HDTV10A, barely out of warranty, can't find a
service or training manual anywhere yet.
It seems to power up at plug in and won't turn off/on, draws about a 1/2
amp current, appears to have the major voltages as far as Vs, Va, etc., and
the lesser voltages that I can find marked (5V, 12V, etc). Heat sinks get
warm all over it. But no picture whatsoever. Also the blue VIZIO logo on
the front doesn't light up. The only two boards available, that I can find,
are the power supply and main (digital) board. I'm leaning toward the main
(brain) board, since there's no logo or response to buttons, and there's
voltages everywhere, but I'd sure like to verify it if I could find a
manual, or any second opinions are always welcome.
Thanks for any help. |
nobbyv
Posted: Sun Nov 08, 2009 8:49 am Post subject: Re: Vizio VP422HDTV10A plasma no pic |
Any progress here? I've got a Vizio VP50HDTV10A with the same symptoms. I do have the service manual for your TV I can send you. |
mariusz
Posted: Fri Nov 20, 2009 7:47 pm Post subject: |
I just repaired mine that was doing the same thing,It was the main board that has all the inputs and the tuner.I cant say for sure yours is the same without seeing it but it sounds like it. |
nobbyv
Posted: Sun Nov 22, 2009 11:30 am Post subject: |
Can you clarify the exact part # you replaced? On mine, the board that has MOST of the inputs (HDMI, component, etc) does NOT have the tuner; the tuner is on the board just to the right of that one. Just want to make sure I am replacing the same part.
Thanks! |
russm
Posted: Tue Jan 19, 2010 8:20 pm Post subject: did you get it woking? |
I have same set and same problem, was going to order logic board. Did you get yours working? |
