2004FLHRSI
Posted: Sat Aug 13, 2011 9:11 pm Post subject: Vizio VS420LF1A power supply? |
Vizio LCD VS420LF1A.
Won't power up from panel button or remote, yet has the front 'Vizio' pilot lamp in amber.
Probing the power supply, seeing 5 volts on the connector going to the main digital board, but 12 volts is absent.
Lines on the connector are labeled:
Inverter
DIM
5 V
12 V
GND
Does the power supply board receive a trigger signal from the main board (inverter line) to start 12V and the lamp supplies? Or is the supply likely at fault?
The heat sink on the controller is getting warm, so think the board is functioning, somewhat.
Any clues from the experts?
Power supply number: 0500-0405-0700
Main digital board: 0171-2271-2813
THANKS!
Matt |
