VX37L blotchy/green blue pink vertical lines
cyphertek
PostPosted: Sun Mar 07, 2010 7:42 pm    Post subject: VX37L blotchy/green blue pink vertical lines Reply with quote
Specifications
TV make: Vizio 37" FP
Model: VX37L HDTV10A
Chassis: 1712-0101-1130 / 1712-0101-1140 (I think these are the chassis numbers)
Background
Friday: I replaced the MainBoard with a refurbished one and it looked great!
Problem
Saturday: It turned on Ok 1 time in the morning. Later in the day I turned it on and the picture was extremely blotchy / fuzzy.
After about 15-20 minutes the picture restored and looked great, like Friday.
Today: Every time the unit is turned on, it looks like the above pic.
I noticed it has green, blue, & pink vertical lines if the cable box is turned off.
What have I tried already?
I tried "Restore All Settings" and tried pulling the power cable out for a few minutes - no change.
Is this a bad MainBoard? The problem is present on every input, so it doesn't seem like an external signal issue. I would like to exchange the MainBoard since it is refurbished (maybe the next one won't do this). The TV is not under warranty so I wanted to get some more opinions. Thank you in advance for your insight.
PostPosted: Sun Mar 07, 2010 7:54 pm    Post subject: Reply with quote
Let's go back. Way back. BEFORE Friday. Very Happy
What was the reason(s) (symptom) that a refurbished replacement MainBoard was obtained and replaced?
There's only one thing worse than a "pulled from service" board ... a "refurbished" board. Rolling Eyes
cyphertek
PostPosted: Sun Mar 07, 2010 8:18 pm    Post subject: what came first, the chicken or the egg Reply with quote
Thanks JTS1957. Here ya go > http://www.riddledtv.com/forums/vizio-vx37l-backlight-only-no-response-from-side-buttons-t1389.html
PostPosted: Sun Mar 07, 2010 8:39 pm    Post subject: Reply with quote
I get confused quite easily as I get ancient... Confused
Myself, I would have kept the same thread going.
Always give the set at least two shakedown runs before proclaiming victory.
My opinion (then and now) is still the main board.
cyphertek
PostPosted: Sun Mar 07, 2010 9:06 pm    Post subject: adventures in forum management Reply with quote
I agree with you JTS1957, it could have been appended to the other thread. But I started a new one since this seemed like a different issue, IMHO. The other thread's title is different than this issue - the term "topic centric" comes to mind... Mr. Green
Thanks for the replies JTS1957. I will post what turns out with the replaced MainBoard.
PostPosted: Mon Mar 08, 2010 12:14 pm    Post subject: Reply with quote
Poorly seated or oxidized ends of the LVDS cable can cause this symptom.
cyphertek
PostPosted: Sun Mar 21, 2010 12:01 pm    Post subject: picture is perfect now! Reply with quote
I replaced the MainBoard and am no longer having this issue. Thank you all for the input.
