Westinghouse LTV 32 Fuse Problem
navjas73
PostPosted: Wed Jul 21, 2010 5:46 pm    Post subject: Westinghouse LTV 32 Fuse Problem Reply with quote
My westinghouse ltv, which I use as a computer monitor, stopped working after some sort of power surge (All electronics in the room shut off). I checked the fuse, and it was blown. (5 amp 250 V slow blow ceramic 5x20 mm) At an electronics store an employee suggested I try a gdc 5a- a 5 amp 250 V time delay glass fuse. After plugging in the power cable, the fuse immediately blew. The employee said that the fuse should have worked, and that if it didnt, the tv might have another problem. Should the replacement fuses that I bought work? Does anyone have any other suggestions for fixing the tv?
PostPosted: Wed Jul 21, 2010 7:14 pm    Post subject: Reply with quote
Fuses usually keep blowing for a reason.
navjas73
PostPosted: Wed Jul 21, 2010 7:26 pm    Post subject: Reply with quote
PostPosted: Wed Jul 21, 2010 7:35 pm    Post subject: Reply with quote
Generally any two adjacent (or non-adjacent) pins on any device (capacitor, Diode, Transistor, MOSFET) will NOT read very low ohms (with the exception of coils & transformers).
navjas73
PostPosted: Wed Jul 21, 2010 8:12 pm    Post subject: Reply with quote
cool thanks i'm going to check that now
navjas73
PostPosted: Wed Jul 21, 2010 8:25 pm    Post subject: Reply with quote
As of right now, the zd 902 diode is the only thing reading around 0. Should it be?
PostPosted: Wed Jul 21, 2010 8:43 pm    Post subject: Reply with quote
Pull (unsolder 1st) either end and test it again. If still "around 0" out of circuit - it's Bad.
