Westinghouse LTV-32w6 HD
judah
PostPosted: Fri Dec 18, 2009 3:24 pm    Post subject: Westinghouse LTV-32w6 HD Reply with quote
I've been trying to repair this tv. When ever I push the power button the led just blinks on and right back off. I test all the parts on the power supply every thing was good. When I reconnected it, it came back on. But when I tried to turn it off it stayed on. So I hit surge protector so I could move it closer to the cable cord. Try again and it just blinks again. Anyone have any ideas?
PostPosted: Fri Dec 18, 2009 8:28 pm    Post subject: Reply with quote
Do not know much about this brand, however.
This symptom is common in some brands.
Disconnect and leave disconnected the T-Con ribbon cable (carefully and do not tear) and try to turn the set on.
If the set turns on the backlight may come on. You will not get a picture in this condition but the backlight may turn on. If it does, observe to see if there is a colored starburst condition on the screen.
Reason to do this.
If you have children (not trying to pick on them of course) you may have a broken screen. (you cannot see the break on a LCD when the set is off.) These screens are fragil and are easily broken and if you can get the backlights to light a broken screen becomes VERY obvious.
Here's hoping your screen is ok.
judah
PostPosted: Fri Dec 18, 2009 9:01 pm    Post subject: Reply with quote
Thanx I'll give it a try. The brand Westinghouse btw .
