westinghouse LTV27W2 LCD half a pic other half is mulitcolor
Tony_
PostPosted: Wed Aug 06, 2008 10:46 am    Post subject: westinghouse LTV27W2 LCD half a pic other half is mulitcolor Reply with quote
working on this unit has a split screen left half is perfect video and sound
right half has colored bars of yellow and blue and pink but if u look u can see the video in behind it anyone got any ideas? called andrews electronics dealer for westhinghouse
the "main" module is shockingly cheap 160 bucks by far the cheapest module price ive ever seen for an lcd but im not sure if the inverter board is the issue or not?
inverter board is sold only with the front screen and is already no longer available...
Dennis_
PostPosted: Wed Aug 06, 2008 10:46 am    Post subject: Reply with quote
Did you check to see if set has "split screen" mode with out a signal going
to the input ?( like PIP only big)
just a thought
Jim_
PostPosted: Wed Aug 06, 2008 10:47 am    Post subject: Reply with quote
I could be wrong but, this sounds like the old 200v boost voltage filter problem. It would cause either jail bars or wide bands of color distortion from the right side. I had to quit working a few years ago so, I cant look up the manual to tell you what to check. It couldn't hurt for you to just look for low micro farad capacitors in those supply lines.
Steve_
PostPosted: Wed Aug 06, 2008 10:48 am    Post subject: Reply with quote
Sounds like possibly a defective display to me. Jim, that's an LCD, doesn't
have that boost voltage on it as there is no CRT. But it is either the
display or the digital processor board. Good luck finding either one.
PostPosted: Wed Aug 06, 2008 12:10 pm    Post subject: Reply with quote
I would first unplug and examine the LVDS cable for corrosion. Common problem. If cable is ok Steve is most likely correct.
