When discharging crt do I need to unplug?
karuzenterprise
PostPosted: Thu Aug 19, 2010 8:54 pm    Post subject: When discharging crt do I need to unplug? Reply with quote
Do I need to unplug the power plug, the ariel cable and the audio video cable from the broken tv before I discharge the crt Question
Another question the aquadag is a covered spring with plastic wrap so when discharging crt do I need to connect the clip directly to the spring not the plastic wrap Question
PostPosted: Fri Aug 20, 2010 7:19 am    Post subject: Reply with quote
NO.
Metal to metal works well. IF CRT has a charge you will hear a loud pop / snap.
PostPosted: Sun Aug 22, 2010 4:45 pm    Post subject: Reply with quote
my vote is disconnect it from everything.
Better safe then sorry.
If the CRT SNAPS, you're going to jump at least a little. I still do every time.
