GBertolet
Posted: Wed Aug 01, 2012 2:36 pm Post subject: Wirewound Resistors |
In troubleshooting my tv set I noticed that many of the voltages were higher than what was on the schematics. I measured several of the wirewound resistors on the circuit boards, and they were all at, or near zero ohms resistance. Their values originally ranged from 2 to 100 ohms. Their physical sizes varied from 5 to 15 watt. Is it common for these type of resistors to change like this? |
Posted: Thu Aug 02, 2012 7:06 am Post subject: |
I'd suggest lifting one end of the resistors and measuring to confirm. |
GBertolet
Posted: Thu Aug 02, 2012 8:13 am Post subject: |
I have already done that. |
Posted: Thu Aug 02, 2012 10:35 am Post subject: |
GBertolet wrote: | 2 to 100 ohms |
Not a large voltage drop across such low value resistors.
IF you have a 100 ohm resistor that reads (out of circuit) lower than 80 ohms or higher than 120, replace it. |
GBertolet
Posted: Thu Aug 02, 2012 11:18 am Post subject: |
Everyone of the wirewound resistors I removed from the circuit to test, reads 0 ohms. |
Posted: Thu Aug 02, 2012 3:33 pm Post subject: |
Meter and correct setting?
For example, a DVM set on 'diode test' WILL give zero reading for all small value resistors. |
GBertolet
Posted: Thu Aug 02, 2012 6:39 pm Post subject: |
I borrowed another meter, and got closer to advertised readings on the resistors. Thanks for the help. My increased voltage problem on my tv set lies somewhere else then. |
