zenith pv4661lk rear projection dead?
suckerpunch
PostPosted: Sat Dec 18, 2010 1:30 pm    Post subject: zenith pv4661lk rear projection dead? Reply with quote
i have a zenith rear projection tv made in juarez mexico 1993 model pv4661lk that wont power on. a few months ago it would turn on for about 30 sec to a min then shut off and now it wont turn on at all. i have looked at fuses and all look fine. is something overheating? any help or advice would be appreciated.
sdtv
PostPosted: Sat Dec 18, 2010 1:38 pm    Post subject: Re: zenith rear projection 1993 dead? Reply with quote
Check the high voltage block. Take it out and look at it.
If it has cracks and burn marks on it then it is bad.
It can also short out.
Also remove the flyback lead from the high voltage block and check it with a meter.
If you get any reading at all then the flyback is bad.
These are very common parts to fail.
It could also be a bad solder joint.
suckerpunch
PostPosted: Sat Dec 18, 2010 1:44 pm    Post subject: Reply with quote
forgot to mention i know nothing about tv repair, thank you for the fast reply, where would the voltage block be? there is a kinda buzz/hiss when pluged in just wont turn on
sdtv
PostPosted: Sat Dec 18, 2010 1:48 pm    Post subject: Reply with quote
Yours may be one where the whole chassis will come out as a box.
The high voltage block is where the 3 big wires coming from the picture tubes go.
They twist and pull out.
suckerpunch
PostPosted: Sat Dec 18, 2010 1:52 pm    Post subject: Reply with quote
would you happen to know a website i could order a replacement from? have searched google and found nothing
sdtv
PostPosted: Sat Dec 18, 2010 7:07 pm    Post subject: Reply with quote
http://www.bluestar-online.com/A_17196_12_Zenith_High_Voltage_Block_p/a-17196-12.htm
