Zenith SLS2555S Horizontal line.
pensacol
PostPosted: Fri Sep 25, 2009 3:12 pm    Post subject: Zenith SLS2555S Horizontal line. Reply with quote
Working on this set. Found on the internet to replace RX3209 1 ohm 1/2 watt. I cannot for the life of me find this on the board. I can't find a schematic either. Does anybody know where I can find this component at?
curt wolfe
PostPosted: Fri Sep 25, 2009 4:18 pm    Post subject: Reply with quote
Sounds like a surge resistor off flyback and going to diode for b+ to vertical ic.
pensacol
PostPosted: Fri Sep 25, 2009 4:35 pm    Post subject: Reply with quote
It also said it was a fusible resistor. Do you know of a good place to find schematics? I have found alot as eservice, but some are hard to find. I will check where you said. The flyback and the vertical IC are on opposite sides of the board. You gotta love working on these things when the boards are full of dust and you spend more time trying to clean it off to where you can read the numbers. I'll go check on that now and if I find it I'll post the location here for future reference.
