Zenith Guest
Posted: Sat Jul 21, 2007 1:57 am Post subject: Zenith TV Service Menu |
* Service Menu #1
Press and hold the {MENU} button on the remote and
the {MENU} button on the TV at the same time,
until the first Service Menu is displayed.
* Service Menu #2
Repeat the above sequence:
until the second Service Menu is displayed. |
Zenith Guest
Posted: Sat Jul 21, 2007 1:57 am Post subject: Service Menu Access |
* Press and hold the {MENU} button on the remote
and the {MENU} button on the TV at the same time
* If a password screen comes up:
again, until the Service Menu is displayed. |
Zenith Guest
Posted: Sat Jul 21, 2007 1:58 am Post subject: Service Menu Code |
* Press and hold the {MENU} button ON THE REMOTE
until a 4-digit password screen is displayed.
* Then try any of the following codes to
access the Service Menu:
{0} {0} {0} {0}
{7} {7} {7} {7}
{8} {7} {4} {1} |
Zenith Guest
Posted: Sat Jul 21, 2007 1:58 am Post subject: Service Menu Codes |
* Press and hold the {MENU} button ON THE REMOTE.
(The menu on the screen will disappear)
* Now Press and hold the {MENU} button ON THE PANEL.
* Keep both buttons pressed until the Service Menu is displayed, then release the 2 buttons.
* Using the remote control buttons:
{MENU} = Toggles between two menu pages.
{UP} {DOWN} = Selects the item for adjustment.
{LEFT} {RIGHT} = Varies the value
{POWER} = Exit service mode and saves adjustments made. |
Zenith Guest
Posted: Sat Jul 21, 2007 1:59 am Post subject: Service Menu Key Sequence |
* Turn the TV on.
* Hold down the {MENU} button on remote until the on-screen menu
disappears or "Welcome Message" appears then release the {MENU}
button and within two (2) seconds press the following five buttons:
{9} {8} {7} {6} {ENTER}
or
{9} {8} {7} {6} {DISPLAY}
* The Service Menu will be displayed.
