mutt15668
Posted: Sat Jan 30, 2010 1:23 pm Post subject: Zenith Z27A11G Completely Dead No Power |
I have a Zenith Z27A11G TV I think the module number is 9-1791. I plug it in an nothing happens when i hit power. I took the back cover off and inspected the 2 fuses i could see(FX3410 & FX3402) Both came back with 0 OHMs. I do not see anything burned up or anything on the board. I am not familiar with how tv's actually work and am pretty fuzzy on the differences between capacitors, transistors, resistors, etc. Are there some common componants to check? I do not have a schematic or anything so the only way i can find componants is by looking for them on the board. I checked the voltage of the wall outlet and of the cord and of the connections under the board where the cord plugs in. All were good.
Any help of this would be greatly appriciated. If i need to give you more info let me know and i will try to find it |
Posted: Sat Jan 30, 2010 6:09 pm Post subject: |
All have caused "Dead Set": RX3401 &/or CX3416 &/or IC3431 &/or CX3231 |
mutt15668
Posted: Sat Jan 30, 2010 6:11 pm Post subject: |
Thank you for the information,How do i check each of those componants. Is there a certain value i need for each?
Thank you for your time and help |
mutt15668
Posted: Sat Jan 30, 2010 6:21 pm Post subject: |
Also When testing the componants should i have the power plugged in or leave it unplugged? Do capacitors need voltage applied to give a good reading Also say i find something is bad do you think a store like radio shack would have replacement items or do i need to search for a specialty store? |
Posted: Sat Jan 30, 2010 7:07 pm Post subject: |
If after reading the following you feel uncomfortable doing any of this, please stop and obtain professional assistance.
Resistor and caps can be checked with a DVM. Resistor should read very close to value printed on it, (color code - look it up), if resistor is open, report before replacing and trying the set. All caps/resistors best tested with at least one side pulled out of the circuit. If DVM has capacitor feature you can test for value, otherwise DVM will only catch leaky/shorted ones. IC is the only part that you can tell by the voltages you are measuring (reference HOT ground) and comparing to voltages on schematic, but since you don't have one you could test first for Switch Mode Power Supply secondary voltages and if none present obtain and install a new one (substitute). |
mutt15668
Posted: Sat Jan 30, 2010 7:23 pm Post subject: |
I am having trouble locating RX3401. I think i looked about everywhere. the board that this person has posted at http://www.riddledtv.com/repair/pics/zenith_Z25A11S-2.jpg
looks very familiar to what i have. I found EX3401 and CX3401 (empty) on the HOT side I also see RX3400 that bridges Hot and cold.
Also i found an ICX3431 is this the same as IC3431? |
Posted: Sat Jan 30, 2010 7:46 pm Post subject: |
Near regulator and yes, ICX3431 is same. |
